Explorer Junky
- March 15, 2010
- Grand Rapids, Mi
- 1997 XLT 4 dr 5.0
I have read a LOT of posts on people trying to get rid of the drivers side sag. Most try what I did, and replace or add leafs to the rear end. This WILL help the rear, but, not the other issue of the dreaded lean. That is... the driver side TORSION bar is also sagging.I did everything that a lot of you have and replaced the leafs added a AAL and still had the sag. It wasn't until I told a laid off Ford Mechanic working at the tire shop I go to, about the issue that it finally got fixed. I looked and the torsion adjust screws yesterday, and saw that the driver side is almost all the way in, and the passenger side is almost all the way out. So, if you are frustrated with the lack correction in your lean from all your hard earned $$ into your rear end.. get the front level first!!
