BAgee87
- February 8, 2014
- 2001 Sport Trac
I've done A LOT of research on this and done all of the simple stuff and even fixed some other things that should help once I figure the root of the problem out.
I'm getting 10ish MPG. The engine runs and sounds perfectly fine. I just purchased the truck from a buddy and he said he NEVER got below 14MPG and that was a worst case scenario.
When was enquiring about the vehicle the transfer case motor was bad and the 4x4 control module would mess up frequently. He replaced those got it going and then I bought it. Since then I have replaced the spark plugs, gave it a oil change with seafoam treatment in both the gas and oil. I also noticed the truck wasn't heating up properly and changed the thermostat out on it and that all is going great but hasn't helped with the milage issue. I'm at a loss. There are no check engine lights or anything and it seems to run fine. Could the issues it had with the four wheel drive have something to do with it like its not disengaging properly or does it stem from something else?
Any help, Tips, or trouble shooting info would be great! Thanks in advance.
