vetgal12
- July 28, 2007
- 1999 Eddie Bauer
I did a quick search for this but really couldn't find a difinitive answer. My 99 Explorer V-8, has 175k miles on it. It has a 373 limited slip. I had to replace the rear diff cover because it was rotted, and was starting to leak. Unfortunately, the fill bung is so corroded, that there's no way to get a ratchet in it. I tried cleaning it out, but it has literally changed shape. I purchased a new cover, and gasket, and put a self tapping oil plug in the upper right hand section. It was the only place where there was clearance. I need to know what the capacity is, since i don't have the use of the fill bung. From what i've seen, it going to be between 2.5, and 3 quarts. Does anyone have the exact number? Don't want to underfill, it, and certainly not overfill it. Thanks..............
