gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
I ran into issues with that stupid POS Yukon kit when I did my D35 some years ago. Seems they can't get their **** straight on it for some reason (I guess go figure... they seem to think this Dana axle was made by American Motors Corp., which hasn't been in existence for over 23 years now )
Mine had a wrong inner pinion bearing (I.D. was too small), and completely lacked any pinion slinger shims (only including shims that went behind the inner bearing race inside the housing). Fortunately I lucked out as I had to bring the pinion in a hair, which allowed me to reuse the original slinger shim, plus one added shim behind the race. My original bearings were like new as well.
As for shim locations, mine had none between the bearings and carrier, they were all between the bearings & housing. Any chance your carrier was swapped over from a Jeep rear D35?
*whew* glad I'm not the only one then.
the pinion bearings seem to be correct, and both carrier bearings are correct.
removed the inner pinion race and installed the slinger between the race and housing.
guess I'll hafta take a wild guess at pinion depth then... no numbers etched onto the pinion head, except for the "serial number" to match it with the ring gear. And that wasn't even etched on, looked like it was written on with a pencil. It disappeared as I took a sanding sponge to see if the numbers were hidden beneath the black crap the gear is covered with.
Only other numbers are stamped, and none would relate to pinion depth.
no clue what may have been going on with the front; I did buy the truck used with just shy of 100k, and it was previously used as a commercial vehicle. Although there were shims between the carrier bearing race and housing also.
Which is why it really confused me that shims fell off with the carrier bearings when I pulled 'em.
I think I may have some shims that may work. Leftovers from my rear install kit, plus some shims from my solid pinion spacers.
Unfortunately I forgot to check the pinion depth of the original pinion; by any chance do you know what the "nominal" pinion depth is? I can't seem to find that number anywhere. Even my workshop manual doesn't list pinion depth.
