jbwilli
- February 14, 2012
- marietta ga
- 1997 SPORT 2009 EXP EB
Sorry JB. If I'm hearing you correctly, you're saying that even when the interlock mechanism is fully retracted, you still can't pull it out of park.
As you can see, this thread has pretty much become dedicated to the interlock issue. I wouldn't wish your repair on anyone. Good luck!
YES YES, now you understand correctly! My hope is that one of the notches in the park pawl ring gear is damaged AND that it can be hand filed back to smooth. I can see how if you were still rolling forward and selected PARK before coming to a complete stop, that the park pawl could enter the notch and slam you to a stop and possibly dent the park pawl and/or ring gear notch....OR it could be as simple as a weak or broken park pawl return spring. If either of the above are true, I can drop the drive shaft and remove a few bolts to remove the rear transmission cover (this is a non wetted area) and gain access to all of the above and repair it. IF that park pawl ring gear needs replacing, the transmission would have to come out! .....more to come!
