Cstoliker
- July 19, 2008
- 2000 Explorer XLT
95 explorer XLT manual transmission. Let me list everything that is wrong, and see who thinks they are all related and means the GEM module needs to be replaced.
*4wd/4wdlow lights blink 6 times every 2 minutes @ 4wd does not work. Lights start blinking almost immediately after ignition is turned on, even after the battery has been disconnected and before the truck has been started or moved. 4wd does work manually using Brown wire mod, (T-case and CAD work)
*Door chime goes off all the time when drivers door is open weather the key in ignition or not.
*Intteiror lights do not come on when doors are open. Interior light can be turn on manually
* TCS relay clicks about 6 times when ignition is turned on.After being off for an hour.
