Btw Izwack, what do you think about my shock idea, since you've been running air shocks on your SAS?
As far as the concept of running both a regular shock and an air shock -- I think thats not really needed because if you're going to install an air-shock, then you dont really need the regular shock because the air-shock can be valved and filled with the proper oil/nitrogen ratio to resemble the same curive as the regular shock. Thats like running dual shocks on each wheel on an Explorer -- the vehicle itself does not have enough weight to require dual shocks even in most off-road situations. But other than being able to change the shock's characteristics, what advantage would this have over the regular torsion bar + regular shock system?
As for the torsion bar and just an air-shock idea, I think this would work but again, what advantages would this have over the normal torsion bar + regular shock setup?
But having said all that about air-shocks, I would not run an air-shock for "general off-road" use vehicle that will see at least as much asphalt as off-road trails. But why would I say this?
An air-shock is a highly specialized shock design that requires tender-loving-care. Air shocks are really great for rocks, but not for "general off-road". Because the seals are absolutely critical on an air-shock in order for it to keep it working properly, you must minimize the amount of dirt that comes in contact with the shaft of the shock. This is one of the many reasons why I dislike mud -- or if I have to travel over mud, I go very slow in 4wd to minimize the spatter. These seals are also very sensitive even to the fluids that are already on the vehicle. During the first test run of my vehicle up in Paragon, I managed to get some brake fluid on the shock shaft and a few weeks later, the shock's bearing body (which houses the important seals) was no longer working properly because of the fluid. Air-shocks must also be refilled with nitrogen every few months (depending on the pressure you run and volume of nitrogen in the body) so I'm not sure many general off-roaders are up for that.
Think of an air-shock as a scalpel where as say a leaf spring is an army knife. If some one told you that you're going to need a knife but did not tell you what types of cuts you're going to make in the near future, then you'd probably pick the army knife since it can be used in plenty of general situations and is very durable. But if you knew for a fact that you were going to perform some high-precision cuts (like in a surgery), then you would probably pick the scalpel.
I know you're trying to think out of the box and I praise you for that (and I hope I'm not putting down your hopes here), but I think you need to focus not on what suspends the vehicle weight because there are many ways to do this depending on your preferences, but instead, focus on the limited-travel IFS system itself -- which is one of the main weakness of the 2nd gen Explorer in off-road situations. If you can somehow make the example that I gave above (about the centered differential), and you made a kit for that, you will EASILY outsell any other existing competitor as you're IFS system will have so much more travel than the rest.
