- March 23, 1999
- Parsippany, NJ
- 1996 XLT
So, I finally decided that I didn't have the time to put the OME-36 springs in and brought my '96 to a guy, Luigi, that has worked on Explorers (add a leafs etc.) and other trucks a lot and really wanted to do the job. I had the OME springs, OME shocks, and a set of Energy Suspension poly bushings for the rear springs.
1: Energy Suspension (and EVERY body else) only makes rear leaf kits for 91-94 Explorers, but I heard on this site that up to 97 still are the same so I got the poly bushings any way. Luigi Calls and says that the bushings for the front are good, but the rear of the spring are too small (at least for the OME springs) so I ok'd him to send them out to some place in Patterson to have correct size bushings pressed in. No problem yet, I just eat the cost of the Energy Suspension kit (unlsess I go retrun it).
2: The Energy Suspension kit also comes w/ bushings for the top of the shackle (where it mounts to the frame). So Luigi removes one of the shackles and bushings and finds that the bushings from the E.S. kit also don't fit up there. We call Ford... there is no replacement part. Call other dealers of suspension parts... no catalogs offer a replacement for post '94 upper shackle bushings. Go to Hackensack spring on the recommendation of 2 Ford dealers, great place, shoulda gone there in the first place. Well there really is no replacement (they called another Ford dealer and went thru all their catalogs), but Bob (the man at Hackensack Spring) did go thru a bunch of bins and came up w/ a 2 possible replacements (the stock ones are different sizes on each end) that could work, so I bought them ($9 bucks, what the heck?) so I brought them back to Luigi. In the mean time he realized that one of the bushings from the E.S. kit for the springs might be able to work in the upper shackle spot so he's gonna make a decision and put one of the choices in.
So what gives? I've heard quite a few guys put in the OME springs w/ no problems. Heard of lots of guys that put in extended shackles w/ no problem. Are you just not supposed to remove the uppper shackle bushing? What if it does wear out? Ford wants you to buy the entire frame w/ the bushing already installed, that's a bit cost prohibitive!?! Please help!!
Let's hope there's no problem w/ the shocks!!
