imq707s
- July 5, 2000
- Springfield, Missouri
- 1997 Mercury Mountaineer
I've got a 97' Mountaineer (same as an X) with a 5.0 in it. It's got over 120,000 miles on it and is starting to get a little weak. I use it to pull my boat and race car all the time. I'm thinking about pulling the motor out this winter and doing a full rebuild (bore .030" over, new pistons/rings, bearings). I figured that while I've got the motor out of the truck, it would be a good time to do some mods to it.
I've built a bunch of sb Chevy motors for drag cars, but I've got limited experiance with fuel injected 5.0 motors. Can I do any porting/polishing to the heads without having to get the computer reprogrammed? What about putting in a little hotter cam? Will that require computer work also?
I know that I want to build low rpm torque for pulling, but a little top end HP increase would be great also.
Instead of messing with a new cam and porting the heads, would I be better off with doing a stock rebuild and adding a supercharger?
Any advice would be great. Thanks :exporange
