Technical Service Bulletins
2004 Explorer - US (English)
The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply.
09-12-12
5R55S/5R55N/5R55W TRANSMISSIONS - SHIFT CONCERNS, LOSS OF 2ND, 3RD AND 5TH GEAR, INCORRECT RATIO DTC'S - PROCEDURE TO INSPECT AND REPAIR SERVO PIN BORE WEAR
09-4-2
4.0L - DTC - P0505 / P0506 / HESITATION / LOSS OF RPM / DIFFICULTY STARTING / LOW IDLE RPM
08-21-11
4 WHEEL DRIVE/ALL WHEEL DRIVE - WITH CONTROL TRAC - SHUDDER ON ACCELERATION/DECELERATION OR BINDING ON SLOW TURNS
08-19-3
UNITIZED SEAL DIAGNOSIS - LEAK / GREASE OIL SEPARATION - AXLE BEARING SEAL 8.8 IFS, 8.8 IRS, AND 9.75 IRS AXLES
07-21-2
4.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY
07-20-5
REAR POWER WINDOW MOTOR INOPERATIVE/STUCK IN THE UP POSITION
07-12-11
BATTERY DRAIN - 4X4 - NEUTRAL TOW MODE
07-12-3
RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-5-8
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-4-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-1-7
MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15
ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-21-19
HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-20-5
PARKING AID SPEAKER INOPERATIVE - DTCS C1742 AND C1743
06-19-14
NO CRANK / STARTER TERMINAL FATIGUE
06-18-16
IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP
06-17-10
MIL ON WITH DTC P0463 OR ERRATIC FUEL GAUGE OPERATION
06-15-8
KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY
06-11-11
ADVANCE TRAC WARNING/CHIME WHEN KEY IS TURNED OFF
06-7-1
NEUTRAL TOW CAPABILITY - SERVICE KIT REQUIREMENTS
06-4-4
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
06-3-7
LOW TIRE INDICATOR ON - TPMS SYSTEM SENSOR WAKE UP
06-2-12
MIL ON WITH PCM DTC P0463 AND/OR IC DTC B1201 - FUEL GAUGE DROPS TO EMPTY OR SLOW TO UPDATE AFTER REFUELING
06-1-3
LEATHER SEAT MATERIAL CRACKING
05-26-2
MIL ON DTC P0191 WITH OR WITHOUT VARIOUS DRIVABILITY SYMPTOMS AND/OR ADDITIONAL DTCS
05-25-8
NOISE FROM REAR WHEEL HUB BEARINGS
05-24-2
BODY - LIFTGATE GLASS APPLIQUE DAMAGED/CRACKED - SERVICE PROCEDURE
05-23-3
REAR AXLE NOISE REPAIR
05-22-8
WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-21-11
DOOR SPEAKER INOPERATIVE - TERMINAL CORROSION
05-21-8
DELAYED OR HARSH REVERSE ENGAGEMENTS - 5R55S TRANSMISSION - VEHICLES BUILT PRIOR TO 09/23/2004
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-17-8
CHIRP NOISE FROM FEAD BELT WHEN A/C COMPRESSOR IS ENGAGING
05-16-11
SAFETY BELT RETRACTION SPEED
05-16-4
DRIVELINE 1ST ORDER VIBRATION/BOOM/DRONE
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-13-6
BACKGLASS DIFFICULT TO CLOSE
05-10-16
NO START/HARD START ON COLD SOAK - 4.0L ENGINE
05-6-4
FALSE PARKING AID WARNINGS
05-6-1
WRENCH LAMP ON AND NO DTC STORED
05-4-16
FRONT SEAT(S) SLIGHT MOVEMENT WHEN ACCELERATING AND/OR DECELERATING
05-3-10
SAFETY BELT WEB STOP BUTTON SERVICE
05-3-9
MIL ON AND/OR RUNS ROUGH/MISFIRE - DTCS P0300-P0308, P0316 AND/OR P0171/ P0174, - 4.6L ENGINE
05-3-8
INCREASED TURNING EFFORT DURING LOW SPEED SHARP TURNS - FALSE 4X4 ENGAGEMENT
05-3-4
MOONROOF SQUEAK AND/OR RATTLE NOISE - CORNER INSERT REPAIR
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
05-2-7
5R55S TRANSMISSION FLUID LEAKS FROM CONVERTER HOUSING AREA - DTC P1783 - VEHICLES BUILT PRIOR TO 12/12/2004
05-1-5
REAR POWER WINDOW(S) INOPERATIVE
04-26-20
THROTTLE PEDAL RESPONSE ON TIP-IN
04-24-6
NOISE DURING A/C OPERATION FROM REAR OF VEHICLE
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-24-1
RATTLE OR VIBRATION FROM REAR SEAT ENTERTAINMENT SYSTEM DVD PLAYER - DEALER INSTALLED UNIT
04-22-12
GEAR SELECTOR LEVER - INCREASED EFFORT TO SHIFT FROM DRIVE TO PARK
04-22-11
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTC'S) P0172, P0175, P0171 AND/OR P0174 - 4.0L SOHC ENGINE - VEHICLES BUILT PRIOR TO 10/4/2004
04-21-12
4.0L - ROUGH IDLE IN DRIVE
04-19-10
OIL LEAK FROM OIL FILTER ADAPTER - 4.0L SOHC ENGINE BUILT BEFORE 4/1/2004
04-19-5
FRONT WINDOW CLUNK NOISE
04-18-3
A/C HOOT NOISE WHILE DRIVING
04-17-15
FRONT AXLE TUBE SEAL LEAK
04-17-4
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS
04-17-3
RATTLE FROM REAR SEAT ENTERTAINMENT SYSTEM (RES) DVD PLAYER
04-17-1
MESSAGE CENTER - DISTANCE TO EMPTY DISPLAYS THREE DASHES
04-14-6
RATTLE FROM DVD SCREEN LATCH ASSEMBLY
04-14-2
NO CRANK WITH DTC B1601 AND/OR B1213 - PATS SECURITY ACCESS ISSUES - 4.0L ENGINE
04-13-3
BODY - HEADLAMP - MOISTURE IN HEADLAMP
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
04-4-5
BODY - TRIM - PAINT PEEL-OFF - ROOF RACK SIDE RAIL
03-26-3
BRAKES - ABS LAMP ILLUMINATED AND DTC C1235, C1236, C1237 - VEHICLES WITH DIFFERENTIAL-MOUNTED REAR WHEEL SPEED SENSOR
03-25-6
ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/2003
03-23-2
BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS
________________
TSBs found:71
