DrkPony
- July 6, 2002
- Delaware County, PA
- 2004 Mounty Premier AWD
When i pressed my 4x4 button, I had no lights at all. I took the electric motor off the transfer case and cleaned it up. When I pressed the 4X4 button i could see the motor spin. When I pressed low range nothing happened. Could this be the switch on the dash? Also after I initially put the electric motor on nothing happened. I back the bolts off a little bit and then it worked. Should i put washers on the bolts, or should i just not tighten them alot? Feels great that I got it to work without payin someone a few bills.
