EDITED! Please read the relay info at the end...
This is the best solution so far, and by far the cheapest before you really have to start delving, so by all means, try this first.
Circuit breakers are not really the best thing to use for car audio applications. Please visit the following site for an in depth review:
Dead Link Removed
Perhaps you should just test to see if the amps respond to the remote first before you really dive into some work. Just take the remote line and connect it individually to each amp just to see if they'll even turn on.
Rock, I remember you asking about how to wire up a relay. Just for a reminder, you can use a normal relay from Radio Shack, the boxy one with four pins on it. It's your basic 30 amp automotive relay.
Pin 85: Goes to your radio's remote lead. In between the relay and the radio, put your .5 amp fuse.
Pin 86: Ground it
Pin 30: Connect to a hot power source, fuse this as well, close to the battery if that's where you're connecting it.
Pin 87: Goes to the components. It's easy enough to run all the remote lines and crimp them together with a connector that will connect to the remote relay pins. You can also, do it down the line if you wish.
If you want a switch to control your relay as well, you can put it between the relay and head unit, or relay and ground.
Lastly, you need to go to Radio Shack and buy a "rectifier" or "switching diode", it's tiny. You can get any of these part numbers: 276-1101, 276-1102, 276-1103, 276-1104. In a normal electronics store you're looking for type "1N4001".
Solder this in between pins 85 and 86 *with the anode side pointing to the positive connection, pin 85. The anode side is the side with the grey line on it.
That's about it. If i missed it, I hope someone catches it.
Jon
Extra stuff: to fuse the main power wire, most components will pull less than .1 amps per component, fans from .5 to 3, depending on size. However, you don'g have to add up all the fuse sizes if you don't want to. You just have to put a fuse size smaller than the total wire capacity. So for like 14g wire, 15 amp should be fine. The fuse is there so that if it grounds out, it won't catch on fire, by transferring more power than it can handle. When it does, it melts and catches on fire, though with a relay wire, maybe not. The above information kindly sent to me by Perry Babin of
http://go.to/bcae
[Edited by JTang on 11-10-2000 at 05:44 PM]
