Greasing Drive shaft/ u joints | Ford Explorer Forums
ravekid
Wilmington, DE
98 Sport
i have a 98 explorer sport and i went to lube up the drive line... and i discovered that there are no grease fittings anywhere!!! how how can i grease the u joints??? any thoughts are appreciated
replace the factory U-Joints with U-joints that are greaseable.
couldnt you just install grease nipples or is that not an option with this case?
I dont think that can be done because the u-joints were not designed for that.Besides you would also have to drill them and then tap them.Were would the grease go also?
U-joints are fairly cheap(i believe they are only around 10-15$).I would just replace them with greaseable ones,then hit them with a show of grease every second oil change just to be safe.
thanks yall..., ill just leave them!
