SBJ420
- June 12, 2006
- Windsor NS
- 95 XLT
Grinding from front right, got pics!
my 94 4.0 xlt is starting to make a bad grinding noise from the front right. It is usllay fine but every so often it will make a spinning noise then a bad grind. And some times makes a grinding when the breaks are applyed. It also seems to be pulling that way also. Its not a wheel bearing but Iam thinking it is a spindle bearing? or somthing in the U joint?
so it goes ZZZZZZZZZZZZZZZZZZ than grinding. than it stops and works fine
Any ideas?
Any ideas?
