96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
Any hints on how to fix the "smiling rear window gasket?". Mine got loose after taking off the plastic door interior trim. It will not hold tight on the metal flange and falls right off. It can't be tucked into the plastic either. Is adhesive a good solution? Problem is that water gets in that area and fills the inside of the rubber trim. Even if I do manage get it to stay, the next rain will puddle water in the rubber channel and take it right off.
