Stackindimes
- March 14, 2018
- MN
- 13 ex limited
Hi all,
I'm new here and have been having major issues with my 2013 explorer limited, 3.5 awd.
Bought it 2014 with 52k ran great. At 60k I had the great idea to put in E85(yes it is flex fuel) I was almost empty when I did. First tank, CEL came on was told it was normal from dealership, second tank stayed on and developed hard cranking. I stopped using and went back to regular gas.
I'm now at 120k, work I have done since 72k has been 2 new cats, 4 O2 sensors, fuel system cleaner, all new plugs twice, all new coil packs, new injectors, new intake gaskets, new evap purge canister.
Still hard extended cranking times it will literally time out and have to push the button a second time, raw fuel smell and CEL still on.
Took to an indy last week, replaced all of bank 2 injectors due to 1 of them dumping fuel in. Starting improved but still not right. Took it back and the are testing the fuel system again. Now it shows all injectors are leaking, including the new ones from last week. He has tried 3 different brands and all are leaking by.
The odds are pretty small to have so many bad injectors so I'm wondering if anyone has heard or came across this before.
Thanks for the time
Thanks for the time
