Harmonic Balancer replacement | Ford Explorer Forums
Avancamp
Gentryville, IN
2005 Explorer XLT
I am considering changing this part due to it being wobbly and I have a knock if you will motor noise. Anyone know where I can get the best deal on one? Part number? Thanks in advance.
You'll probably find Dorman or OE.
OE, there's a dealer that sells online super cheap. Hopefully someone will recall their name.
If it's wobbly, do NOT drive it anymore. When it breaks loose, anything and everything in its path will be taken out.
Okay thanks, yes it is definitely wobbly/not true. The tensioner pulley also bounces. Hopefully someone chimes in on that site, so i can get it ordered.
Bump anyone?
I would recommend a Ford OEM Balancer
Tascaparts.com
Balancer 8L2Z-6B321-A $155.37
You will also need a new bolt as they are TTY E7RY6A340B $6.03
Thanks guys
Looks like there is a new design compared to the one I have installed. The one I have on it now is the weird tealish color. Any input on what's the difference?
They have the same part number 8L2Z6B321A they just are diff color and seems where ther sensor reads is different.
Fords OE design failed, as I understand, they have an updated version. Call the dealer to verify.
Okay will do
