XCIX xls
- January 29, 2002
- San diego CA
- 99xls
I recently purchased a 1999 2wd 4 door xls w/ 46000 miles and automatic transmission.
Afer driving it around I've noticed that there seems to be a sort of vibration coming from the steering wheel as if something was loose. For example when I drive at speeds over 55mph you can clearly feel some sort of vibration coming from the front end, which translates to a vibration on the steering wheel ( from side to side ). Not only that but while driving around town I can almost hear something in the front suspesion as if something was loose. not a loud clank or pounding sound, but just enough so that I can feel it through the steering . Even when I brake I feel a slight rattle. Anyways the dealer balanced the tires after I went there twice and also lowered the tire pressure to about 28psi. This has defenitely helped in giving a smothered ride but yet I can still feel like something is not completely solid up front, especially at higher speeds like 70mph. What could this be?
Thanks in advance for any replies!
