SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I'm trying to figure out the source of an oil leak I have.
Anyhow, I'm about 90% sure it's the oil pan gasket and it's leaking on both sides about half way back and I see oil on three of the oil pan bolt heads nearest the tranny. I'm just looking for someone to chime in and let me know it is not unusual for a 2002 4.6L with 150K miles on it to start leaking oil around the pan gasket.
If that's the case does a re-torque of the pan bolts generally fix the problem?
- It's not the front crank seal. I recently replaced it while replacing the timing chains.
- It's not the valve cover gaskets. I recently replaced those while replacing the timing chains.
- It's not the oil filter adapter. That was leaking a few years ago but I changed out the gasket to fix that.
- I don't think it's the rear main seal but not 100% sure.
