TTSaleen
- September 17, 2013
- Apex, NC
- 2003 Explorer XLT
I did this recently as my oil pan gasket (lower) was leaking at the back of the pan, near the transmission.
It was a pretty simple job.
Just drain the oil (during a routine oil change).
Remove all bolts.
Pull pan off and clean.
Remove and discard old gasket.
Install new gasket.
Reinstall pan.
Install bolts and torque between 8-10 ft-lbs of torque.
Refill oil.
Here's my video on it.
Ryan
Remove all bolts.
Install new gasket.
Reinstall pan.
Refill oil.
Ryan
