rocket22
- August 28, 2007
- La Grange, IL
- 2002 Explorer xlt 4 wd
Scenario; 1995 Explorer 2WD (is that an issue with the trans hook up? The engine has 191K and is rusty appears to have a head gasket or Intake gasket leak. I can get an engine to swap for 400. I am not going to try the head gasket replacement since I can see a number of broken bolts and other problems. I would think a swap would be better. Or just part it out and buy something else. IS there any good head gasket fix in a bottle recomendations? The truck body is not good, lots of other little issues, but the engine runs fine outside of the leak issue. The leak is not a slow leak, and it is not a freeze plug. Any ideas? Can you seal a leak from the outside? Jen Weld? Any other options?
