SuperKirby
- June 23, 2012
- Central MN
- 1993 Explorer XLT
About a year ago I replaced the head gaskets, heads, rockers, and a few other things in my 93 Ex. All was well until about 3 months ago. I noticed the one day my exhaust looked a little steamy again. Curious, I checked my overflow tank and it was empty. Filled it up and as soon as I did it started bubbling. Just a little disappointed. As far as I can figure I must have not cleaned up the block as well as I thought I did.
So, now I'm gearing up to do it again. I'm hoping to put it off about a month until it warms up at least a little.
I learned a lot doing it last time - like the value of ratcheting wrenches and copper anti sieze. But I have a few questions and also want to tackle a couple other issues while I'm at it if I can. First a couple questions...
I ordered my gaskets and parts from Rock Auto and plan to again. I thought I ordered the heavy duty gaskets all around, but when they arrived none of them were. I already had everything torn apart and wasn't able to wait the time it would take to send everything back and order new, so I went with the cardboard stuff. In order to avoid this mistake again, can someone provide specific links and part numbers to the right parts? It looks like either FelPro or Victor Reinz make a good set of gaskets but not sure which ones to order so I get all the gaskets to do a complete job AND get the heavier ones.
Second question - My AC doesn't work. I suspect the refrigerant is low and it's still R11. From what I understand converting to R134a is expensive so I don't plan to do it. As I recall last go round the compressor was a pain to work around, so I'm considering pulling it altogether, as the pulley has also started a pretty annoying squeal. Can I just disconnect the hoses and pull it all out and get a shorter belt? Is there a part number for the belt or is this a bad idea?
Last but not least, I've owned almost all Fords. One thing about them I love is the heaters, especially living in MN. My Explorer is the first one that isn't good. The PO put a new heater core in it and I changed the t-stat. I've noticed the temp guage fluctuates quite a bit, and never gets above the "N". Maybe this is normal. I know the blower motor or switch needs replaced, but I don't think this is reponsible for the lack of warmth.
I know I covered a lot here but figured it was better than starting 10 different posts. Any help that can be provided would be greatly appreciated.
Thanks.
Vince
Thanks.
Vince
