hey...i have a 1994 X and i was just wondering if it would be possible to convert the headlight bulbs from 9004's to H4's? just curious if there were any kits out there or any way to do this? any ideas would be great....thanks
why would you want to convert it? an h4 may put out a little more light but our housings werent designed for the more extreme heat that they would produce....
PIAA doesn't make 9004's? WHAT WHAT WHAT??? I think you've been misinformed, they have superwhite, xtreme white and standard PIAA 9004 bulbs! I've had all three!
I know this is a bit old, but I was doing a search on converting from 9007 to H4. PIAA has H4's called Super Plasma which are sweet bulbs. They look similar to the Mercedes purplish colour. I had them in my '89 Nissan 240. They are the same wattage as the 9007 and therfore should be ok. I was just wondering if anyone knows anything about doing this conversion. All you should need is the H4 plug, right? If so, where would you get it?
Originally posted by 98BlackXSport I know this is a bit old, but I was doing a search on converting from 9007 to H4. PIAA has H4's called Super Plasma which are sweet bulbs. They look similar to the Mercedes purplish colour. I had them in my '89 Nissan 240. They are the same wattage as the 9007 and therfore should be ok. I was just wondering if anyone knows anything about doing this conversion. All you should need is the H4 plug, right? If so, where would you get it?
