Headlight bulbs | Page 2 | Ford Explorer Forums
Headlight bulbs
what is the most watts i can put in my fogs before housing and wires will melt.
if they were too melt are they expensive to replace?
Good qustion, can you replace the 9145 45 watt foglight bulbs with 65 9005 (or 9006 I don't remember)?? the bulb base seems to be the same
I can't necessarily answer your question, but I can tell you that just because the bases are the same, doesn't mean that the bulb will work properly with the housing. I had accidentally bought a set of 9004 bulbs for my stock lamps, and my hi-beam light came on permanently. I found out I was supposed to have bought 9007 bulbs, which I then did, and that solved the problem. The reason for the hi-beam indicator having been on when I had the 9004s installed was due to their current draw being higher than what the 9007s were, therefore fooling the electrical system into thinking I actually had my hi-beams on when I did not. Just a little food for thought.
I replaced my fog light (9145) with a 9005. Other then the fact i had to trim a tab and getting in was a little harder, everything seems to work fine. I am using Eurodezigns 6000k lights in both my head light and fog, and so far i have had no problem. Technically it's only be a day so we will see as time progress. The headlights are DOT approved and same watt as a regular h13 so i am not concerned with anything melting. Since my fog were 45watt and now are 65watt, I am continuously checking to make sure i am not melting anything. So far so good. I am going to try and run the fogs for a while tomorrow to see if anything happens I figured a good hour or so of them running while driving around, would cause melting if it were going to happen. is that correct to assume?
I was looking at those eurodezigns bulbs yesterday. How are they working out for you?
I like them so far. I have the 6000k Super White Ultra. I absolutely love the color. The brightest white that I have had, and I have had Nokya, Silverstars, etc... This is by far the whitest!!! No problems thus far.
If you are looking on ebay, you can get them cheap. I like I got the heads for 8.99 and free shipping and the fogs were 4.99 plus 6.95 for shipping. Cant go wrong for that price.
