Headlight not working, but bulb is OK | Ford Explorer Forums
FOMOCO423
Indianapolis, IN
2015 Ford Explorer
My 2015 Explorer (Base model with 4WD) has just acquired a problem.
The LH (Driver's side) headlight has stopped working. I had been running Philips 9011 C1 bulbs, but I kept my OEM bulbs for spares.
I replaced the Philips bulb with the OEM, and it is still not working. Note: Parking lamp is OK on that side.
Has anyone had a similar issue?
Thanks in advance!
Did you start by double checking the fuse?
Warranty. Use it.
No, I didn't check the fuse because the passenger side headlamp is fine. They would be on the same circuit, right?
Have you checked fuse 17? It is for the LH low beam. Fuse 16 is for the right side. It is shown in your Owner's Manual.
Peter, I did not know that! Thanks for the tip!
