weaselonastick
- October 8, 2007
- Edmonton Alberta
- 94 Limited
Hey folks... long time browser, first time with a question. I have a 94 limited with no headlights or highbeams. All other lights and signals fully functional. Replaced the multifunction switch with three different ones from a wrecker... no change. My prognosis is that the hedlight switch is toast. Here's the problem... the original headlight switch is obsolete... cannot find anywhere (Dealer and the web). The problem is that the Limited has an eletrocromatic rear view mirror which ties into the headlight switch. A current replacement switch does not work (wrong pin configuration). Need help!!! Either i need to get another switch (haven't found one at the wreckers), or modify the wiring to use the current replacement switch... I don't care if I loose the electrocromatic mirror. Original part number is SW2421 or F3TZ11654A. Thanks for any advice! Also posted in "under the hood".
