Alex from GA
- July 24, 2013
- '99 Explorer
On the freeway tonight the headlights blinked a couple of times then came back on. A couple of miles later they went off for a longer time then went out altogether. I followed a car for a while trying the high beams and low beams with no results then I pulled back on the high beam stalk and the lights came on. I could tell by the radio and heater lights that if I released the stalk the light would go out. After about 10 more miles the dash lights went to the dim mode and the lights worked as normal the rest of the way home about 15 more minutes. I did turn the light switch on after they came back on so I don't know if that helped or not. They're automatic headlights. What should I look at to be the problem. I'm old and usually don't drive at night but when I do the lights must work. Thanks.
