Jaysonlee
- February 19, 2008
- Chattanooga, TN
- '01 Limited, AWD, 5.0
First and foremost I would like to say hello! I am a new subscriber to the site. I have browsed through the forums in the past and found some very handy information. Figured it was time to register. Now for my question...
I have 2001 Explorer Limited with 5.0 V8, and AWD. Just about to turn
109K miles. Thought it was well time for a new set of plugs and wires (yeah, I probably waited too long). All plugs came out fine on the drivers side, and got the new ones in without any trouble. Moved to the passanger side, front plug (number 1 I believe) broke off IN the head. The other 3 on the passenger side were so corrided that I could not get a socket on them. Tried heat, penetrating oil, and an e-z-out on the broke plug, but no luck.
Ended up having tp pull the head, (broke an exhaust manifold bolt in the process). Now in order to get the head off we had to rip the manifold off as well (upper and lower). Once the head was off we got the plugs, and broke bolt out, cleaned everything and went to put everything back together and ran into a major problem.
When we tried to put the Fuel Injector Connectors back on the would not clip down. I foudn a small piece of plastic on the garage floor that looks like it was some kind of lock on the Fuel injector connecter. (My helping hand removed them so I did not see how they come off. Can someone tell me What kind of Fuel Injector Connecters these are? Can I repair them? And if not where can i get, and how much will new ones cost?
Thank You SO Much in Advance!
Edit: Here are pics of my Tune up from Hell.
