help- before i commit to buying this | Ford Explorer Forums
stocker
venice, fl
'96 5.0
while in reverse, applying the brakes a moan comes from what seems to be the rear brakes. also there is a grinding sound(in the front suspension?) when making 90 degree turns. i have a seven day trial on this, just bought it... thanks
You're buying an old vehicle. That is why Explorers become dirt cheap. Just front wheel bearings will run over $1000 if this is 4 wheel drive. While you are at it, check to see if the emergency brake still works. They fall apart (I mean it, the shoes fall off) by this time. I've only bought Explorers when they have over 100K on them. They are cheap and I do all the work on them. Between brakes and half shafts, you will be paying someone else more than 1K right off the bat.
hey i live in venice fl.
my name is charlie give me call some can talk:
@ 735-1400 cell
as for the wheel bearing i just had Auto Workx on Warfield Ave. by the Venice Ave bridge, do my bearing done on both sides for $291.63
where did you get the truck from, how many miles, and $$?
