treyeven700
red head step child
- October 1, 2005
- suffolk, virginia
- 92 xlt
ok, i have two issues with two different explorers.
first one (which is the most importent) i have a 1992 ex 4x4 5speed that i lifted and when time and money allowed i converted to rear disk brakes. it had rear abs which i bypased so i could bleed them in the first place, and i had to make a custom line set up, (bent the solid lines and added the disk softlines with the driver side supply line plugged and now i cant get the rear brakes to stop sticking) i checked the calipers and pads, (fine) but when i first start driving the brakes are squishy and then all of the sudden, they start getting really firm and then the brakes are stuck and i cant take it out of first gear because the are sticking so bad....
second, i did a motor swap from a 97 soc motor to a 96 sov motor. i changrd the computer and got everything hooked up, (changed motor mount on driverside and the whole exhaust) i even took the starter wiring and changed that, but when i went to start it, i have juice in te car but when the key goes to the start position i get nothing, i have checked the wiring for bad grounds, and double checked everything to ensure it was hooked up, but still nothing.... the motor swap was done that way because i found a 96 with a blown tranny and my 97 had a blown motor. who would have thought it would be this tough!!
any help wou be greatly appreciated!! thanks Trey
