RKelly2233
- August 26, 2007
- Rochester, NY
- 03 XLT 4-Door Sport
okay, searching here was not easy... there are so many different problems that you all have had with the timing chain and driveshaft that I dont know which ones I really can relate too . So here it goes:
03 V6 4-Door (sohc right?). I have 155K miles. Orig plugs.
Timing chain:
Ok I know I need to replace one of the 2 or both (or so I heard there was 2). It rattles on colder starts initially durring start up (not necessarily cold outside, just when the truck has been sitting for hour or so). When the truck is from 1000-2000 rpm it doesn't rattle, but as soon as I go above I get a little jingle. Same as when im going 45-50 at about 1000 rpm (I can get 21 mpg honestly so its my favorite speed). Would that be the main- or the rear? And should I replace the tensioners or anything else to make sure it doesnt happen again? I can't do it myself, I dont have the tools or knowledge. I have a mechanic that works at a good rate ($) and does honest work.
Driveshaft:
I have that horrible howeling- usually at higher speeds. Im not nervous to have it flushed, and owners manuel says now its supposed to be done around this mileage- but will it help it? What would I have to get into (work wise) to stop it otherwise? or at least to minimize it? I've read hundreds or threads, and I dont know what product to choose- regular, conditioner, etc. I also read that after you do it once, do it again after the next oil change- and itll be much more minimized. Im going to have the Ford dealer do it (I dont mind spending the $150 for someone to do it right) and supply them with the conditioning fluid..
Side note; I dont have them handy but I bought new plugs and wires. That mechanic friend said that he would do them for $100 cash... Ford told me it would be around $800 in labor. Does my mechanic just not know what hes getting into???
Going this saturday to get oil done and PCM flash upgrade...
Timing chain:
Driveshaft:
