JustAnotherMember7
- May 12, 2020
- Twin Falls
- 2001 Explorer XLS
I've got a Monroe replacement in hand. But can't for the life of me get the mounting bolts for the shock off.
Upper bolt: takes a 15mm (bolt) and 17.5ish mm(18mm just slightly too large, nut).
Bottom bolt: 15mm(bolt) and 21mm (nut)
I've used wd-40, a torch, double wrench method, and a sledge to try and loosen those two bolts.
No room on the ground for my breaker bar.
So, I'm going to save myself a TON of frustration and borrow my uncle's angle grinder in a few days and cut them out. BUT...
I need to know the specs for the two shock bolts when I go to my local screw and hardware place.
