help - installing f150 spacers | Ford Explorer Forums
TSTONE
Giddy up!
Oakland County, MI
97 Mountaineer
i need help installing f150 spacers
i've used the search function and i haven't come-up with a whole lot
please help
Disconnect the shocks and sway bar, loosen the radius arm bolts if necassary. Spacers go on the bottom of the spring, and they're shaped so just remember which way the spring goes in and that should tell you how the spacers go in. I think they are marked left and right too. Oh, and you need like a 1 1/8" socket to get the spring nut off the bottom stud. Use a long extension and get at it from the top of the spring. When you put it back together keep the stock bushing thing thats one there.
