'97 V8
- April 2, 2005
- ft. knox ky
- '97 mounty 5.0 4x4 baby!!
Some people say it matters and some people say it doesnt...imo it matters. You can drill a hole and pop in a grade 8 boltsa and nut to hold them together. Yoiu have a breaker bar right? Oh and have a spare 18mm socket....you drop one somewhere in fornt of the rear axle...the bolt under the rear seat if im not mistakin. Make sure you unhook the fan shroud before you do anything. Also when you got the body lift installed, bend the center radiator mounts up while having a friend holding the rad. Then drop it and put those drop down brackets on.
