96ExplorerSport
- July 9, 2006
- Pittsburgh PA
- 96 X Sport 4.0L OHV, 4WD
Hi,
This morning I got in my 96 Explorer only to discover that my power windows are no longer working on both sides. In addition, the the following accessories are no longer working with engine running: door lights, map lights, dome light, under the hood light. First I assumed this was fuse related. My manual list fuse #28 for all these accessories. I checked it and it was fine, I even replaced it just to be sure, did not help. I've checked other fuses (under the hood as well) and everything appears to be in order.
Here is my question. If I let the engine run, pull the fuse, and measure the voltage across, it has to be the battery voltage, right? I plan on doing that when I get home. I think it's a fuse or relay somewhere, but I am not sure where
Thanks,
Sergey
Thanks,
Sergey
