Help with a Eddie Bauer 95 | Ford Explorer Forums
Fonz745
St. Louis
95 eddie bauer
Whats up? I got a quick question, which im sure has been asked before, but would appreciate some help. My factory cd changer has not been working for a while and I dont realy wanna repair it because it dosent even play MP3's. Im getting ready to install a new head unit in my 95 and have already purchased the new wireing harness to run from the factory amp. I just wondered if anybody knew the easiest way to take off the back panel to reach the amp without haveing to remove the back passenger side seat belt? I also wanted to know if anybody knew the best way to pop out the little tabs ( im assuming they are covering screws) that run along the roof and along the back? I tried to get one out but they are pretty stubborn and i did not wanna break one if i could avoid it. Any help would be great....I wanna get this damn thing in so I can really start listening to music again! Thanx.
do you have the JBL system? if not then you shouldn't need to go the fact amp unless you're wanting to bypass it
Yea, I have the JBL system...so I definitely have to get to the amp...which sucks...so I was trying to figure out the best way to get to it.
guess if i'd noticed you said eddie bauer...anyway. you can remove the trim from the passenger kick panel to the pass rear door. the "peel" back the lower part of the back panel to make you connections. much easier to pull that whole back panel off. suggest getting some panel poppers to pull those tabs out (no screws behind them). does the factory sub still work?
nah man...blew that thing along time ago...have subs...but they were professionally installed
