Help with ABS Sensor switch | Ford Explorer Forums
weldtron
Chicago, IL.
'93XLT
'93 explorer 4dr.4x4 xlt
Need Information on R & R of ABS SENSOR front Drivers side. Can You send a link with photos? Doing a front brake job soon and believe this is the time to change the sensor. PLEASE ADVISE.
Thank you,
John Hindel
Welcome to the site Weldtron!
welcome weldtron
Abs sensor replacement
I need help with the abs sensor switch, it needs to be changed. Does anyone have a link or thread with photos on how to do this. I would really appreciate it.
I REMAIN,
John Hindel
Renamed and moved to give better visibility. If you're talking about just replacing the sensor, it's pretty easy (as long as it's not rusted in place). Just take the bolt out of the sensor housing and pull it out. You then un-clip the cable and disconnect the plug.
IF it's frozen in place, you may have to knock it out. This will require you removing the rotor from the knuckle to get at it.
I'd suggest going out and buying a Haynes manual for the truck. Costs about 15-20 bucks and has all this info in it. The manual is written for the shade tree mechanic.
...Just a heads up...I am removing my post from this thread as it originally was about 4x4 motor problem...
...Weldtron has modified his original post #1 twice today :rolleyes:
