Can't get my 91 Explorer to run. All should be right with the world with it. Got spark, fuel but won't run. Any suggestions? Please help and thank you!
Have pressure gauge. 30lbs pressure at the fuel rail. Doesn't seen like injectors are fireing. Nothing happened to her when it was parked. Ran perfect. Just sat for reasons beyond ny control for a while.
Get a multimeter and test the injector plug for voltage as it is cranked,also get a spark tester and check the spark that way to make sure that there is enough spark to fire it.
