Doityourselfer
- June 21, 2009
Hi everyone,
I'm new to this forum today
. My girlfirend recently bought a 1991 Ford Explorer in very good condition with 190 000 kms. I'm currently trying to fix up a few things on it to make just a little better to drive. I recently had steerring problems. The truck was wandering in the road practiclly uncontrollable and there was alot of steering play. I had the truck check out and the wandering turned out to be a seised universal ball join. After this was replaced and the bearings were greased up again the problem of the wandering had stopped. But I noticed that there still was alot of play in the steering so after looking on this forum for answers I found out how to ajust the play using the set screw on the steering grearbox. Right now the set screw is as far as I can screw it in and I noticed once I get the speed up to about 90 km/h and over the play gets worse and makes the truck difficult to control when the road is a little bumpy. I've hade the whole steering system check by a mechanic and all the ball joins, tirod ends, etc are solid. I've run out of ideas, I thought maybe that I could replace the whole steering box but I have know idea if that would really solve the problem, plus its expensive!
I also thought that maybe the link between the two bars in the steering collum might have some play, could this be ?
Another thought is that its seems that when the tilt steering is brought lower that the play seems to get worse, I might be imaging this, dont know.
Does anywone have any suggestions for me ?
