agzaretzka
Elite - G-d Bless!
- May 13, 2004
- Kennewick, WA
- 1991 EB
shrek2much said:so what I have done since was follow your shift motor teardown and rebuild thread, I followed it step by step, it was quite a fun experience and yet educational at the same time how about that (and yes sure enough the little plastic bump washer was devoured but got replaced with rubber fuel line), now assuming I did all this correctly, I am still getting the same response (dim light at all times) but now I discovered that my sh/motor is not functioning or rotating,
Did you 'bench test' the shift motor while it was out, i.e. connect it directly to 12v and run it both directions before re-attaching? If that was fine, I'd follow the diagnostic procedure listed in the word doc that is around here. Ok, post 8 on this thread...
