JoyfulDiscontent
- December 11, 2007
- Minneapolis, MN
- '98 XLT 4.0 SOHC
My explorer is having trouble accelerating, especially from a stop. If I try to accelerate normally, the engine hesitates and makes a distinct puttering sound likes it's going to stall (has NOT stalled yet though). If I accelerate very very lightly I don't seem to have a problem and once I'm going the problem bascially goes away. Runs a bit rough at idle and has stalled a couple of times when in Park.
Ran Scanner and found the followingsorry can't find the paper with the code numbers but here's what I can remember)
I will check the codes again today and repost them exactly
Here's what I have done so far:
My next thoughts were to replace the EGR solenoid, valve, and/or plug wires.
My neighbor also thought I could have a clogged Catalytic Converter. My exhaust does sound like sh**. I also should note that last November my OD went out the the tranny. Took it to the dealer and they found metal in the pan. They told me tranny would fail in about a month or so. Guess not. This acceleration problem doesn't seem to me to be tranny related, but I'm not an experienced mechanic and am not ruling anything out.
If anyone has any suggestions I would appreciate it a lot.
Aaron
- EGR vaccum regulator solenoid
- evap system canister vent solenoid fault
- a fuel pressure code (can't remember which)
- cleaned AIC valve
- checked air filter
- changed spark plugs
- changed fuel filter
- changed PCV valve
- checked fuel pressure regulator (no gas in vaccuum, looked good)
- checked fuel pressure (9 psi @ on position, 39 psi while running)
- cleaned throttle body
Aaron
