mrmcdowell
- April 1, 2013
- molalla oregon
- 1994 ford aerostar XL
i have a 94 ford aerostar XL 2WD with the 3.0L. the problem i am having is that you start the van and it idles high like the throttle is stuck so i took the throttle cable off the motor and it still did it. so then i looked at the relays and tested them and found that one was stuck on. these relays are the ones on the driver side fender between the battery and the fire wall. so i put them all back in and took a screw driver and tapped on the one that i thought was stuck and the van idled back down. does that sound right to any one and also does anyone know what those relays are for?
