high temp lowoil/obd reader | Ford Explorer Forums
Mjlewis
2004 explorer
hello, my 2004 eddie baeur was displaying high low oil pressure and while driving just cut off. it has full power just wouldn't turn over. I attempted to check with the Obd scanner and it isn't reading. I checked my scanner on another car and it works fine. I initially thought it may be the fuel shut off valve but it is fairly new. any suggestions would be a great help.
thanks for the reply. I did check the lighter fuse and its good. the truck has full power but will not turn over so I thought the fuel shut off switch was bad but it is new. the fuses are all good so I'm thinking whatever is causing the EBD to not respond is related to the reason the truck is not starting
does the starter click at all when you turn the key
I actually haven't check that because it died as I was driving. Just cut off but still had power. I checked all connections and tried to read for any codes and it wasn't responding. I check the fuel cut off and still nothing. I think it has got to be electrical cause all fuses are good.
