SplashMan
- January 3, 2001
- Cedar Rapids, IA
- '93 Ranger
OK, here is the deal...
About two days ago on the way home from work I was doing my glance at the gages thing and noticed that the temp gage is pointing strait up and going higher(toward the red line). I imidiatly turn on my heater and the gage stops and then eventually goes down a little and stays there for the rest of the trip home(20min). When I get home and put it in park I notice it is ideling high(usually it idles just below 1 now it is just above 1 1/2). Well it was a VERY hot day(90+ with heat index about 105) so I figure it is the weather and only check the radiator overflow(right were it is supposed to be) and then forget about it. Next morning on the way to work I look at the gage and it is doing the same thing and it is only 75 out side. So I turn the heater on and get to work. When I get to work it ides high again and I check all the fluids and everything is good. After I get home last night (after driving 30min with the heater on full in 90+ temp) I grab the hose and spray the radiator off and get alot of dirt and crap off of it. Well this morning it does the same thing...??? The only engine mods I have are K/N drop in and a drilled air box. It is the 4.0 SOHC with just over 50K.
Anyone have any ideas??
