How about this?... | Ford Explorer Forums
How about this?...
exinprogress
Winchester, VA
'92 XLT
Would using the parts for a Duff Stage II kit for the front with F-150 coil spacers keep me about level If I did a SOA sans the overload leaf and JD shackles? I plan to add a 2 inch BL to this to clear 33's
Suggestions are always welcome as I can't make up my mind...
Thanks
Are you wanting to combine a 2.5" Duff lift and a set of spacers? If so you should be close to level with just a SOA.
Yeah, thats what I wanted to do but I just can't make up my mind on this or the Superlift.
So many choices...so little money...
thanks for the input!
You could still just trim your fenders afterwards and avoid the body lift, unless you want it taller anyways?
4" in front will sit perfectly level with an SOA in rear with stock shackles and no overload leaf like you said. Should be a great setup. I don't recommend the James Duff arms anymore though. I've broken one arm and one tranny crossmember already. Their brackets are good though, and so are the coils. You might want to try front skyjacer 4" or maybe camburg radius arms, rough country adjustable axle pivot drop brackets, and some nice eibach coils. You'll need a dropped pitman arm and extended brakelines with 4" of lift. Oh, and 33s should clear with a little trimming.
