fbc
- December 11, 2010
- Guadalajara, jalisco, Mexico
- '97 XLT 4WD 4.0 OHV
The manual specifications say:
Rear axle fluid:
or
Can this crap get any more cryptic? They forgot to through in that it can only be done on a sunday before a full-moon in the month prior to a leap-year.
Can they just say if your rear axle is this type, buy a bottle of X. But no... they need to add friction modifiers with certain specifications, and tons of other crap!!!
damn, I'm on a rant today.
Rear axle fluid:
Motorcraft SAE
80W90 Axle
Lubricant - for vehicles with conventional axles.
80W90 Axle
or
Motorcraft SAE
75W140 High
Performance
Synthetic Rear
Axle Lubricant - Ref to footnotes 2 and 3 which read:
2 Vehicles equipped with 4.0L SOHC and 4.0L EI engines may have a limited slip differential. If your vehicles is equipped with a limited slip differential, add 4 ounces of additive friction modifier C8AZ-19B546-A, Ford specification
EST-M2C118–A, for complete refill of 8.8 inch and 9.75 inch rear axles.
3
SOHC or 4.0L EFI engines and
3.73 or 4.10 rear axle ratios or
5.0L engines require synthetic rear
axle lubricant. Rear axles
containing synthetic lubricant are
lubricated for life. These lubricants
are not to be checked or changed
unless a leak is suspected, service
required or the axle assembly has
been submerged in water. The axle
lubricant should be changed any
time the axle has been submerged
in water. For Traction-Lok rear
axles, add 4 ounces of additive
Ford specification EST-M2C118–A,
whenever the lubricant is changed.
75W140 High
Performance
Synthetic Rear
3
