bigredscowboy
- July 13, 2008
- High Point, NC
- 2003 Ranger Edge 4.0 4x4
1992 X 2-door 2wd:
Checked all three relays and fuses, which are good. When I turn the key on I get 2 seconds of power to the inertia switch and the red wire on the fuel pump. No whirling/charging. Is there anything it could be other than a bad fuel pump?
I only ask bc I picked one up at a junkyard to confirm that it was in fact the fuel pump before spending a bill on a new one, and it didn't work either (i even cleaned this one up). I got a warranty at junkyard so I can go get another one but I'd like to check it in the parking lot before leaving if possible. Can I just hook the black and red wires up to leads on the battery or do I also need to do something with the other two wires? What can I expect from a good pump?
