yob_yeknom
Moderator Emeritus
- November 14, 2000
- Glade Hill, Virginia
- '97 XLT & '06 Limited
Had a little mishap wheeling and ended up screwing up my exhaust. Now it has a leak and sounds like a 4 banger.
The sound got progressively worse on the long ride home, so I haven't been driving my Explorer and it's driving me nuts. I need to get it fixed!
Basically everything was bent and moved when the entire weight of the front end was put on the two cats. That ended up moving the pipe between the converter and the manifold on the passenger side. Now where the manifold and the pipe connect at the flange, there is a big leak.
I've tried (well, actually my dad did all the work, I can't use my right arm well right now) to get the pipe to go back to where it used to be. (you can see marks on the manifold side of the connection where it used to be 1/8" over) We loosened the nuts at the connection and tried to tighten the side that moved first to move it back, didn't work. We've loosened them and took a pry-bar and tried to pry it over to where it used to sit, didn't work.
Am I gonna have to drop the whole friggin front of the exhaust to fix it? (good old Ford welded both sides together so it all has to come out as one!!)
Any help is appreciated!
Yes, I've thought of duct tape.
I'm afraid it will catch fire.
