What? It doesnt matter to me what he does, heck pour water in the intake if you think it will take carbon off your pistons, I dont care.
I can tell you that Sea Foam works as it promises to, it delivers. Nuff said right? Thats 98% better then most products out there...
He was asking for help on how to do it properly, so advice is what he got. Nobody said, if you dont use Sea foam you are a moron. you guys are basically saying Sea Foam and products like it are not for you. Great!
Whether you think its a good idea or a bad one, who cares, its not going in your engine, and you can talk all day about why not to put it in your engine and thats great, but it does work, but if you dont need it, dont use it.
On my old 2.9L I had some serious compression problems with a couple of the cylinders, I pumped in some Lucas oil addative and the compression came back, why? Because the stuff is syrup and it basically plugged the gaps... Would I pour it into a perfectly good engine? Nope. Did it work like it said it would on a old worn out engine that needed it? Yup.
There you have it, simple. Does every engine need Sea Foam? Nope. Are there some engines that can benefit from it? Yup.
Do you need to change mobil one synthetic oil every 3000 miles religiously? Nope, but I still do.
I probably dont need to change my tranny filter and synthetic ATF in my A4LD twice a year either, but I do.
With 245K miles on my 88, using the truck to tow a #4000 boat all over the mid west, avid 4x4ing, and a daily driver for 7 years now, this stuff works for me.
Oh and people who hydrolock their engines with Sea Foam didnt read the directions..........There is no liquid that you can pour into an engine like that, you can hydrolock an engine with carb cleaner too if you dump a litre of it into the cylinder at once and let the engine die, of course you would probably catch of fire first, but either way you werent following directions.
Carb cleaner works great too.....it does what the bottle says it will do. I use it all the time on my intake, of course I always take my intake apart and clean it by handm but thats just me.......
