How do I know what gear ratio I have? | Ford Explorer Forums
jaybyrd
Tampa Bay, Florida
2000 eddie
Is there any way to tell what the factory gear ratio is? I bought the vehicle used. 2000 eddie 4 X 4, it has the factory ball for towing on the bumper and the air levelling suspension, but not sure what gears I have in the back.
On the inside of the drivers door there should be a white tag with your axel code on it.There should also be a tag on your back axel:)
heres a question to add to this topic, since Im new to Explorers..... what ratios did they offer? or if the changed the available ratios what was offered after 95
Axle Codes - Located on the driver's door
Model Code Description Capacity Ratio
Bronco II 42 Regular 2640 3.45
44 Regular 2640 3.73
47 Regular 2500 4.10
D2 Limited Slip 2500 3.45
D4 Limited Slip 2640 3.73
D7 Limited Slip 2500 4.10
Ranger 72 Regular 2200 3.08
74 Regular 2200 3.45
82 Regular 2700 3.08
84 Regular 2700 3.45
85 Regular 2750 3.55
86 Regular 2700 3.73
87 Regular 2700 4.10
96 Regular 3200 3.73
F4 Limited Slip 2700 3.45
F5 Limited Slip 2750 3.55
F6 Limited Slip 2700 3.73
F7 Limited Slip 2700 4.10
K6 Limited Slip 3200 4.10
Explorer 43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
